Old 09-05-2008, 10:58 AM
Ronbo Ronbo is offline
Cobra Make, Engine: Kirkham #570 w Shelby FE
If you lack the neutral switch, (also built-in to TKO's) the easiest way would be to use a hydrolic switch like one used on the brakes.
Other than that a trip to NAPA for a switch from just about any car will do. Keep in mind the swtich is somewhat special as it's designed to travel much past it's "make" point.
Wouldn't hurt to have a bypass switch hidden under the dash in case something fouls.
