Old 09-05-2008, 11:56 AM
Don Don is offline
As Jay mentioned, the emissions testing for CT Composites ( kit cars & replicas ) is still exempt, but as of August 1, the emissions/systems hardware must still be installed based upon the year, requiring documented proof which is not defined, of the engine as noted below. CT will not have an exemption program similar to CA.
......reply regarding the August 1 CT Composite regulations received from Harry Gough, CT DMV Principal Engineer: The first item is the question/statement and then Harry's response
Q: The Federal EPA mandate for installation of the emission hardware did not exist when the CT General Assembly passed the Composite Emission Exemption in 2007.
A: It is this EPA hardware mandate which requires with no options or alternatives CT to issue the new Composite emission regulations. The EPA requirement has been in effect at least since 1994. If you care to review their information it is available at
http://www.epa.gov/otaq/imports/kitcar.htm
Harry Gough, PE
Principal Engineer
State of CT DMV
203-271-5413
From the EPA Regulation:
The components of the drivetrain (engine, transmission, differential) must be exclusively or substantially used and/or rebuilt. Regardless of the combination of new and used components, the engine must be used or used and rebuilt. The engine block and cylinder head(s) must be used, other components of the engine may be new. "Used" means the component has been in a vehicle that has been titled to an ultimate purchaser. A rebuilt component is defined as a used component which has been refurbished with new or other used parts.
Excerpt from the CT DMV Composite Regulations:
Effective August 1, 2008 all composite vehicles (except motorcycles) presented for a composite inspection will be required to be equipped with the following emissions systems based on the year of manufacture of the engine used in construction.
Emissions controls must match the year of the engine used in the composite vehicle. Documented proof of engine year must be provided by the applicant. This information will be verified for accuracy and the presence of all required components will be verified during the inspection.
Note: This requirement will not apply to vehicles with engines purchased prior to August 1, 2008. Documented proof of engine year and purchase date must still be provided at time of inspection.
All Light Duty Vehicles with Gasoline Engines were equipped with the controls indicated below (Lt. Duty = below 6001 lbs GVWR till 1978 & below 8501 lbs GVWR after):
Year of Engine Emissions Controls Required of All Vehicles That Year
Pre - 1966 None
1966 - 1970 PCV, Variable Advance Distributor
1971 – 1978 PCV, Variable Advance Distributor, Evap. Canister, and Thermostatic Air Cleaner or Air Injection System
1979 – 1988 PCV, Variable Advance Distributor, Evap. Canister, Thermostatic Air Cleaner or Air Injection System, and CAT
1989 – 1995 PCV, Variable Advance Distributor, Evap. Canister, CAT, Computerized Engine Management, O2 sensor
1996 – current PCV, Electronic Spark Control, Evap. Canister, CAT, Closed Loop Computerized Engine Management, O2 sensors, Fuel Injection
