Old 09-05-2008, 01:29 PM
carmine carmine is offline
Cobra Make, Engine: spf 2112 *427 stroker windsor
Try 20 lbs of tire pressure. if you look in your owners manual they sugest 18lbs for street and 25lbs for track. Improves ride quality as well as traction. This may sound like not enough air but you have to take into consideration that your car only weighs 2400 lbs. and these pressures will give your tire the proper contact patch with the road.
