Old 09-06-2008, 08:44 PM
flipscobra flipscobra is offline
Cobra Make, Engine: Superformance aluminum427
anytime you pull a distributor out of an FE you have to be very carefull, because if it does not have the star washer on the shaft when the motor was built, it can fall out. If it goes into the oilpan you can get it out thru the drain plug.
