Old 09-07-2008, 04:48 AM
Double Venom's Avatar
Double Venom Double Venom is offline
dvcobra, (now that seems strange!)
Assuming you are getting it welded or your doing your own, you only use short pieces but the same witdh. Weld nuts to the inside of the control arms matching the nuts you use for the sway bar. I suggest "FLANGE" nuts, just make sure they line up with the pre-drilled holes. Box in the top and bottoms, sides aren't necessary. When done you will have a set of $300 control arms that can take anything you and your Cobra can dish out.
The bar fits on the outside of the control arms by the way.
DV
