09-07-2008, 12:47 PM
KY
The pilot of the input shaft should be fully supported in the bushing/bearing, but it shouldn't go far enough to touch the crankshaft behind the bushing/bearing. If it does, it could put a forward load on the crank, pushing it into the thrust bearing when you bolt the trans up.
