Old 09-08-2008, 02:14 AM
COBRANIP COBRANIP is offline
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
How do you plan to use your Cobra? GENERALLY SPEAKING......
.."Softness" is more associated with spring rates and tire size than suspension type;
..In a drag race environment the straight axel is probably a better choice;
..On a bumpy road or track the Independent suspension is generally superior;
..On a smooth road or track there is not much, if any, difference (ON A PROPERLY DESIGNED SYSTEM).
This sort of learning is half the fun of building a Cobra!
Good luck.
