Old 09-08-2008, 10:23 AM
undy's Avatar
undy undy is offline
All driers are limited by line size and cubic inch of capacity. Generally speaking, pretty much any auto hi-side drier can be used as long as it can be hooked up effectively (line size connections etc.), you can make the connections and it has any required switches.
The larger the condensor (thicker too) the more surface area/tube linear footage you have, meaning you have the capability of cooling more refrigerant hot gas.. As with the drier, you can generally use it as long as it can be hooked up. This is all without knowing exactly what compressor you're using and what vehicle it was originally intended for. Compressor's have a variety of pumping capacities, although somewhat minute. There are many different configured condensors (line location). You'll have to do some research as to which ones have the right line locations.
..next up to bat.
Dave
