I have a Lonestar and have had similar problems. I totally agree on burping the system. Get the front several feet higher than the back, as high as you can, then fill the system. Suggest the temp guage is not accurate which may be due to a bad voltage reference. If you don't have a 100 amp alternator, get one. This will keep the fan running full speed at all times. The high output coils and fans we run can easily pull down the electrical system on anything less.
Good luck.
