Thread: Odd request!
Old 10-12-2001, 06:19 PM
Turk's Avatar
Turk Turk is offline
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
excelguru
Keith,
I don't need to bother Dan. I kind a got something done.
It will fit under the dash right behind the dash support tubes.
Thanks for the offer.
Satanpez
I had a hidden antenna in my boat, and it worked pretty well. Major difference was being out on the water without too many obstructions. Also the ignition noise maybe a problem. I will give it a try with the hidden antenna, it should be good enough. With a CD changer in the trunk I should be all set.
Bill Wells
I have seen those line of radios. They serve the purpose on Hotrods etc. I did not like the electronic quality of the components offered. I wanted a bigger selection to choose from, and there is no other way other than to look at all the conventional items offered in aftermarket.
Dominik
I have access to "glued to the windshild" type of antenna. As small as our windshields are, it would be a distraction. I am going with a "rubber Duck" or a convential 34" AM/FM mast, under the dash or in the trunk even if I have to srap it in plastic or tape.
TURK
Thanks to all who offered help.
OBAMA IN in 2012
