Old 09-10-2008, 12:08 AM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Since the rack cannot go down and your roll center is below ground level it follows that if you raise the inboard pickup points for both top/bottom w/bones by 1" you would be killing two birds with one stone- fix both the bumpsteer & raise the roll center at the same time- sounds like its too low anyway. Before doing anything you should check that your wishbone pickup points are in a position that will give good camber settings in roll etc as well. If you are going to shift stuff around it pays to consider all factors-saves doing it twice.
Jac Mac
