Old 09-10-2008, 11:44 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Default 3550 to tko600 speedo drive swap problemo
the unit that drives the speedo from the 3550 is a mechanical/electrical combo and it will not fit the 600 without some grinding on the mount.
so is it correct that these will not interchange?
also there are a few more hookups on the 600, mid left side front are two brass threaded posts, upper portion behind shifter is a pigtail, and right side has some kind of covered connection. anybody know what these are for? i figure the upper left behind shifter is neutral safety switch.
thanks
