Old 09-12-2008, 09:12 AM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Ball Joints
Mic and others
I have found that Howe Racing makes a K727 style balljoint that you can get a 1/2" extended stud. Not as much as I need but a step in the correct direction.
Has anyone used these and your experience?
If I use one of these and also shim the taper joint with .012 shim stock, that moves the LCA outer joint down 5/8"
Paul
www.65shlb.com
www.prdcrrct.com
