Thread: brake part help
Old 09-13-2008, 05:10 AM
Blittleton's Avatar
Blittleton Blittleton is offline
CC Member / Sponsor
Originally Posted by rocket7171 View Post
I'm having a problem with my e-brake coming apart in right side rear rotor. The backing plate won't keep hold of retainer and drum pads for e-brake come loose. I've bent slot for retainer three times but it continues to pull back out and releasing shoes. I need to know model and year of backing plate so I can get one from BMW. I've ordered wrong part once and would like to get it right next time. For now I was able to get a bolt and lock nut through hole and still able to keep spring tenison correct on retainer hole but would like to fix it right.
Vintage thought it maybe a 95 325i. Way too big.
Tony, Reg Some help here?
thanks
tom
#188
Tom,
The bolt and lock nut is the way Backdraft does theirs now. They make a new plate of the dust shield. But I did find an place for you to get one of the original type of dust shield.
http://data.bmrparts.com/bmwparts/18721441930006U.html
this will need to be slightly modified to fit and limit noise.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
