  #21 (permalink)
Old 09-16-2008, 08:12 AM
patrickt patrickt is offline
Originally Posted by Ron61 View Post
Pacrickt,
You are right for most people, but my engine was built for racing and then when I got to old and sick, it just didn't work out well for cruising with that ratio and a .6 split. My cam came in at around 3600 RPM and with the .6 split it effectively raised my rear end ratio to 2.10 with the street tires I used. So at the 1900 RPM at 70 MPH I was lugging the engine and a .8 would have been better for that use. I would say that 80% of my cruising was done in 4th gear as the traffic and speed limits stopped me from getting the engine up to where it ran well.
Perfect example of a need for a .82 and not a .64 gear. If you have a rear numerically lower than 3.5, or an engine that isn't at least awake below 2500rpm, I wouldn't go with the .64 trans. It can be a tricky call, and if in doubt, I'd go with the .82 gear.
