Old 09-16-2008, 07:42 PM
tcrist tcrist is offline
Default Alignment brackets
Will the guys that e-mailed me for a copy of the print that I made up for the alignment brackets resend me their e-mails? I had a computer glitch and lost some of my latest e-mails.
Tom,
Your bracket will be sent out shortly. I had my welder cut off the bracket and re-weld it on the other direction. I figure that way you will have a matched set of the original brackets. The new ones that I am making might be a little different than the original.
DV,
Which holes do we use on the cobras, the lower set or the uppers? If we only use the lower set of holes I could make the brackets without the upper set. I think it would look much better without the extra holes.
Terry
