Old 09-17-2008, 04:33 PM
rdc767 rdc767 is offline
Cobra Make, Engine: A&C
.Alright I got the new primary metering block with the power valve hole. I used the 6.5 vacuum valve.
It went together well. I used 68 jets in the primary and 76 in the secondarys.
I have a question on the accelerator pumps. I have the cam set to squirt the primary pump as soon as the throttle opens. This works well. And the cam and arm don't bottom out the primary pump.
Should the secondary pump start to squirt as the secondarys open? If it does…..
I cannot seem to figure out on how to set the cam on the secondary accelerator pump to start as they secondary butterfly valves open and not bottom out the accelerator pump
Secondary Side
Primary side upside down
