Old 10-15-2001, 10:17 AM
CobraEd's Avatar
CobraEd CobraEd is offline
Don, I am not an FE guru, but I know the basics and I am not clear on some things here.
__________________________________________________ __
Are these hydraulic lifters? For sure???
Are you getting oil flowing up thru the lifters and out the tops of the pushrods?
Did you pre-lube the lifters (assuming they are hydraulic)?
Are all the valves taping or just one or two?
Are these old used lifters with a new cam (a big no no)?
Are these FE lifters or "other" lifters with the same bore diameter? Are you sure??
Based upon how you answer the above questions would help me to make some suggestions.
Ed
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
