First check the shifter adjustment in neutral. The transmission shift rails, detents and interlock pin are the brains of the operation not the shifter control box. If one of the rods is adjusted to far one way the transmission thinks it is in gear and will not allow it to go into another. If one of the detent springs is broken the transmission may not shift to neutral all the way and cause the shifter to not be able to select any gear. Then after you move the shifter around things get back to position and it works again. It sounds complicated but it is really very simple.
