Old 09-25-2008, 06:41 PM
Jimbocobra's Avatar
Jimbocobra Jimbocobra is offline
Cobra Make, Engine: Backdraft#357, 392CI Ford Racing, 459hp, 455ft/lbs , TKO 500, 3.43 Gears, Ceramic Coated Headers, Victor Jr. 750cfm, 17in Halibrand wheels, Sterling Gray/Silver Stripes, Gray Leather, Nitto NT05
Default Clutch, Gears, Heat??? Please help!!
I have been reading these forums and this sounds like some people have the same issue as I do. Basically, when the car gets hot I have to wrestle with the gearshift to get it in gear, it grinds when I put it in reverse. It is getting to the point where there were several times I literally could not get the gear shift into any gear. I don't beat on the car; it is a Backdraft and has less than 3000 miles. To all of you who know about this stuff, do you think it is the slave cylinder overheating? If so, is there a consensus on how to fix it. I have heard to replace it with a hydraulic set up, use a heat shield, change the fluids and use heat resistant tape? I am sure I can't fix something like this. #1 What do you all think is the issue? and #2 any know a good speed shop around St. Charles, IL who knows how to fix this?
