  #25 (permalink)
Old 09-25-2008, 06:07 PM
JayBar's Avatar
JayBar JayBar is offline
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
Jimbocobra,
You don't need a speed shop you can get all the info you need on this forum, form people who have been there and done that. You have a hydraulic set up you just have to keep the fluid from boiling. You only need a few tools nothing special set of
open end/box end wrenches.
Your problem is simple, buy a heat shield from Backdraft, change the fluid to one that has a high wet boiling point. I use ATE Blue maybe about $12.00 to 18.00 a can. Suck out the fluid from the clutch master, refill with good quality fluid, open the bleed screw on the slave and pump the fluid through.
JayB
Jupiter, FL
