Old 09-26-2008, 04:39 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by PSERRA View Post
i recently installed tko and twin disk mcloed chulch and bell housing i got a clutch cable only and i adjusted it right but i have a problem that i can't seem to power shift this transmission at 6800 rpm for some reason can any body help my with suggestions.and also the gear just doesn't go in the major problem is 2nd to 3rd shift.
Hopefully you're using a rev limiter.
I had a tough time getting used the shift from 2nd to 3rd using a TKO 600. A short throw shift kit might help a little. The faster you try to shift and jam it into to 3rd, the more it'll fight you. You can be smooth and fast, without putting a ton of forward pressure on the shifter.
Doug
