Old 09-27-2008, 06:25 AM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
More progress this week. We got our rear wheels from ERA! I had the Goodyear Gumball tires installed on the rims and balanced. After installing the wheels on the car, I set the ride height to ERA specs. The car's stance looks great. Here are a few pictures with the wheels and tires on the car:
I had to set the rear shocks at almost the lowest setting possible to get the car to the high side of ERA's recommended ride height. With the adjusters cranked almost to the bottom of the shock, the car is at 5 3/4" from the ground to the frame rail in the back. At this point, the rear coilovers are about 1 1/2" out of the spring pockets with the car jacked up in the rear. The car is only missing the seats and the tunnel at this point, has all fluids in the engine, and has 1/2 tank of gas so I think that I must be near final weight. The issues that I'm seeing may be because of the all aluminum FE that I'm using has less weight than a cast iron big block? It may also be that the car needs a little more time to settle now that its on its wheels. Bob, what do you think about his? Do I need to consider springs which are less stiff for my coilovers?
- Fred
