Old 09-27-2008, 06:38 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Fred-
Once you drive it, the fronts will settle down a little more. I just swapped out an iron block 428 for an all aluminum FE and I did have to drop the front springs a little bit- maybe 1/4" inch or so- to compensate for the difference in weight between the 2 motors. But the stock ERA springs are fine for an aluminum FE. And the car looks great by the way.
Can you do me a favor? Can you measure the height from the the floor to the middle of the fender lip on both your front and rear fenders- I'm still screwing around with my ride height trying to get it where I want it and yours looks pretty good.
Replica is not a dirty word.
