Old 09-27-2008, 07:12 AM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Originally Posted by Chaplin View Post
Fred-
Once you drive it, the fronts will settle down a little more. I just swapped out an iron block 428 for an all aluminum FE and I did have to drop the front springs a little bit- maybe 1/4" inch or so- to compensate for the difference in weight between the 2 motors. But the stock ERA springs are fine for an aluminum FE. And the car looks great by the way.
Can you do me a favor? Can you measure the height from the the floor to the middle of the fender lip on both your front and rear fenders- I'm still screwing around with my ride height trying to get it where I want it and yours looks pretty good.
Unfortunately, I am away traveling so I won't be able to make the measurements for a week or so. To give you a reference, the distance from the bottom of the frame rail at the rear to the ground is 5 3/4". The distance from the front of the frame rail to the ground is 5 1/4".
