Thread: Half Shafts
Old 09-27-2008, 08:16 AM
oleyellar oleyellar is offline
Default Half shafts
If the band clamp is hitting the frame, you need to have the rear end aligned. You can relocate the wheel with the a-arm adjustments and still have the wheels correctly aligned. Or the differential has moved in its mounts. Check for cracks in the center section mounting.....or do the alignment. There are a few companies that make better, stronger half shafts, but they all use CV joints.
