Old 09-28-2008, 02:27 AM
Default Make your own with a high location spot
Michael C Henry Mike I have a LPW cover and had to make a remote setup for my car. Without the breather you are blowing out the seals. I tryed the stock one from Jag and under racing conditions I was blowing out oil from either the seals or the breather and getting the brakes wet( in boards ) I have a 90 degree brass fitting, SS line 2' long going to a small tank with a breather on top. The oil cools and goes back into the carrier. No problems. The combo of heat from the racing, engine and trans heat coming down the tunnel. The rear brakes cause the hot temps in the carrier. So far no problems with this setup. The CSX comp cars run a pump and cooler for the rearend. Rick L.
