Old 09-28-2008, 08:16 AM
MrMagoo's Avatar
MrMagoo MrMagoo is offline
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
I have a G-Force T5 with a .75OD behind my 410 stroker. I have a 3.73 differential. I have to say, I like the .75 OD way better than the .63 that was on there before. With a 3.54 rear, the .82 would produce a similar result, which I think you will like.
However, I am wondering, with the 289 presumably having less torque and with the power range presumably being further up the RPM range, would you be better off getting a higher ratio for your differential, assuming you are using stock gears for 1-4? I drive mine pretty much the way you plan on driving yours and while my motor's torque curve would handle the 3.54, I find I am satisfied with my current setup.
If I can see you, I'm too close
