Old 09-28-2008, 08:40 AM
TButtrick's Avatar
TButtrick TButtrick is offline
If the manufacturer states that you need to remove the shock then you should remove it with no load on the that shock. Jack up the car from the frame and watch the shock and spring until you see the spring unload completely then remove the shock. Removing a loaded spring/shock is simply not smart and is certainly the hard way.
