Old 09-28-2008, 06:17 PM
rokndad's Avatar
rokndad rokndad is offline
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
In my case. the rotor is pointing to the pass side of the engine at the no 1 plug on the cap. The red line looks about right, except I think that after you put the rotor on that dist, the contact on the rotor won't be pointing in that direction. In any event, put your rotor on and it should point to about the 1 o'clock position assuming 12 o'clock is to the front. at zer TDC. If it doesn't then your a tooth or several tooths off.
