Old 09-28-2008, 06:21 PM
SSSammy's Avatar
SSSammy SSSammy is offline
IWC, attach the rotor and it will become clear. It is keyed to only go on in the correct orientation. The electrical contact of the rotor should be co-located with the #1 wire in the cap. Then you will only be off by 14 deg or so - the BTDC advance.
If it is off, pull the distrubutor out and reposition the rotor shaft. Note that the slant on the drive gear will cause a 20 deg or so rotation as you shove the distributor in, so you have to allow for that.
Sam
