Thread: GPS Lap timer
Old 09-29-2008, 02:46 AM
Krait's Avatar
Krait Krait is offline
I reckon if you only wanted a general indication of laptime then a gps based system would be ok.
The problem with gps is the accuracy can vary depending on a number of variables such as the ephemeris data (precise orbital data) from each of the satellites it detects, whether the gps has clear line of sight of sufficient satellites and whether the signal is bouncing of off objects before it gets to the gps receiver (anecdotal reports is that even a bald head can affect the signal).
Google 'gps accuracy' and you'll see what I mean
Using a ground station (DGPS) to transmit a fixed location greatly enhances accuracy but the equipment to receive is expensive and accuracy is reported to be about 3 metres. The US has a system called WAAS but it is unavailable in Australia.
I was involved in a community GPS mapping project in Malaysia. We would be happy if we had 6 metre (radius) accuracy when tracking roads and kept vehicle speeds to <60kph otherwise the track would overshoot on bends.
Hope this helps.
Geoff
