Old 10-16-2001, 06:29 PM
GUMBALL GUMBALL is offline
Default Turkey Pan Fit Question.................
Need some help from you guys with turkey pans:
I bought one from Cobra Restorers. Popped it on the intake, then popped on the carb........... carb won't fit! The carb is 1/8 inch too wide for the pan. I am using a Holley #0-80531 850CFM.
Question:
Do I have a bad pan or the wrong carb? Or, does the pan need some pounding, filing, or cutting to make it fit? Any help would be appreciated.
BTW- any suggestions for gaskets/foam/insulator around the top edge of the pan to seal it to the hood correctly? How does one do about this?
Regards,
John
Better to have and not need than need and not have!
