Old 10-03-2008, 07:53 AM
Barry_R Barry_R is offline
The old rule of .001 per inch of shaft diameter still works pretty darned well. Truth is that as long as you are between .002 and .003 you'll be OK. My normal target for bearing clearances are around .0026-.0028. The bearing engineer that worked with me over my 12 years running Speed-Pro often said that "my phone doesn't ring if they're under .003 - if they're over .003 the phone starts ringing...".
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
