Old 10-03-2008, 10:41 AM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by scootter View Post
I replaced the gas pedal shaft last year. Greg happened to have one that he never used. The pedal was still good.
I you look at the clutch pedal, there is three holes where you can connect the master cylinder. Its are normally hooked to the center hole. My center hole was worn, even though it wasn't much at the hole, the end of the clutch pedal had more then an inch of play. There is no bushing, and I tried to drill the hole bigger with out taking the pedal out, not a chance. So I put it in the bottom hole. You loose leverage, so it was hard to push the clutch in. WAY TO HARD. So the other day I put it in the top hole. Way easier to push the clutch in ( Greg said it is still way harder then his). The only problem is, you lose travel, so I had to raise the clutch pedal up about an inch and a half. So it was way to high. Tim from Dynamic's sent me a new pedal a week ago, so I installed it. I had to sand the hell out of the inside hole to make it fit.
Scott
The only pedal you haven't replaced is the brake pedal...makes sense because you rarely use it.
Doug
