Old 10-07-2008, 08:38 AM
patrickt patrickt is offline
From the Tremec TKO Installation Tips. http://www.ttcautomotive.com/English...ps_117_117.pdf
We recommend GM synchromesh part # 12345349, or Dexron III / Mercon Spec ATF fluid for all TKO transmissions.
Maintenance
Recommended oil change intervals should be based on specific usage. In most cases a “fill for life” is adequate, while in severe applications such as drag racing, or road racing a more frequent fluid change should be prescribed. Excessive heat will cause most fluids to breakdown and ultimately cause damage to the transmission.
