Old 10-07-2008, 09:24 PM
Don Don is offline
CT implemented new emissions requirements as of 8-1-08 using the following standards based upon the year of the engine block:
All Light Duty Vehicles with Gasoline Engines were equipped with the controls indicated below (Lt. Duty = below 6001 lbs GVWR till 1978 & below 8501 lbs GVWR after):
Year of Engine Emissions Controls Required of All Vehicles That Year
Pre - 1966 None
1966 - 1970 PCV, Variable Advance Distributor
1971 – 1978 PCV, Variable Advance Distributor, Evap. Canister, and Thermostatic Air Cleaner or Air Injection System
1979 – 1988 PCV, Variable Advance Distributor, Evap. Canister, Thermostatic Air Cleaner or Air Injection System, and CAT
1989 – 1995 PCV, Variable Advance Distributor, Evap. Canister, CAT, Computerized Engine Management, O2 sensor
1996 – current PCV, Electronic Spark Control, Evap. Canister, CAT, Closed Loop Computerized Engine Management, O2 sensors, Fuel Injection
