Old 10-09-2008, 06:58 AM
Spoooky's Avatar
Spoooky Spoooky is offline
Cobra Make, Engine: 65' SPF (511 CID) FE 427 Alum Block Shelby /Roush 600hp-625fpt sideoiler
That's a good question. How do the rings get stuck? Roush wants the motor to run with very light weight oil, 10w-30wt, conventional only. No synthetic. I thought it might be a heat thing and my motor runs right at about 200 degrees oil and about 210 degrees water. That is right on. I know that the FE/ alumn. big blocks run a little hotter. Mine is right where it is supposed to be. I've been going through a little oil right from the start. Roush does run these wide open before you get them. I don't have the answer. It does run great though. I'll keep everyone up to date as I get the info. Good stuff to know.
