Thread: FE vs. 460
Old 10-12-2008, 04:59 PM
diegokid diegokid is offline
Cobra Make, Engine: Unique
Default Weights
I too almost went with a Bowtie and until there are several thousand miles on the FE I went with I'm keeping my fingers crossed since I have NEVER had a Ford product that held up as good as my Chevy stuff. As far as weight goes here are some numbers I pulled from a Ford forum. The Fe is consederably lighter when you goe with the Alum intake and heads. I couldn't believe the weight of just the cast iron intake when I started buying junkyard motors for this project.
PS: You know that Chevy is making a 427 again don't you? If you used it all the 427 badges would be correct!
ENGINE FAMILY WEIGHT (LBS) WIDTH LENGTH HEIGHT
289/302 Windsor 460 24 29 27.5
302 Boss "Clevor" 500 24.5 29 28.5
351W Windsor 525 25 29 29
351C 335 (Cleveland) 550 25.5 29 29
351M/400 335 (Modified) 575 26 29 29
332-428 (ex.SOHC) FE 625 27 32 29
427 SOHC FE 680 32 34 30
429/460 720 27 34 29
429 Boss 385 635 30 34 30
