10-15-2008, 05:07 AM
PA
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Originally Posted by Merv and Sharon
This is a pic of the Vacuum Regulator Solenoid (EVR) from the Ford EFI. I am still unsure if it NEEDS to connected.
Also there is a component that I seem to be missing: the Barometric Pressure Switch. Again, must I go hunting for that?
Merv
PS thanks for the tip re posting pics - the trick was to know to have TWO windows open at the same time!
If your turbocharged you use a BAP, N/A MAP same component just Vac hose from the intake. You'll notice the BAP pictured has the white collar so a VAC hose won't fit on, the MAP doesn't have the collar..
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
