Old 10-16-2008, 05:40 PM
Double Venom's Avatar
Double Venom Double Venom is offline
True,
A Digital LAZER level. Same one I check the angle of the driveshaft/pinion. I checked the degrees of the floor, then the degrees on the nose of the body (This is where it was most visible, when the body was on and the newly modified hood was on. At first I thought I blew the alignement of the hood scoop. The scoop came out fine, the only thing left was the motor. Took the hood off and laid the level on the brand new large oval aircleaner. Made sure it was down all the way and tight- WallllAAA.......The motor listed to starboard 26's! I think I said a bad word at that point! Out came the OEM frame mount, built a new one and now we are back to plus/minus a half degree.
New powder coat being applied as we speak.
DV
