Old 10-16-2008, 11:23 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Hey Yellar,
and others with internal hyd TO Bearings if you like them more power to you. I personally like an external hyd. set ups. They are easy to adjust, cost effective, will not contaminate clutch disc if a leak occurs, allows stock clutch parts to be used, allows a slight ratio advantage to be used.
Cars light weight allows lighter clamping pressure so crazy stiff pressure plate is not needed. With a 7/1 pedal ratio - 5/8 master cylinder bore - 1 inch slave bore - stock fork length with a quality clutch assembly.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
