Old 10-17-2008, 04:23 AM
Double Venom's Avatar
Double Venom Double Venom is offline
TCRIST,
Without the body being on, no air cleaner it only looked like a small "angle/twist' which you can get if the actual motor mounts aren't sitting in the holes evenly. I simply thought I would have to raise the motor up a little, let the pins settle and we'd be OK....................When it finally came to light I told Ed it was my fault for not catching it immediately. The only defense I had was what I just mentioned, that I had never seen a frame plate welded wrong, (The Jigs don't lie) and my resulting effects from an old stroke- I always list left and thought it looked almost normal!
Actually 26's equated with the aircleaner on to almost a full 1/2" inch! Ooops!.
DV
PS Edward, yes it did thank you. From Florida!? Sure doesn't look like home made or work made! Shame. I owe you another one !
