Old 10-17-2008, 01:33 PM
D-CEL D-CEL is offline
Cobra Make, Engine: SPF 239
Jeri,
I recommend the McLeod Diaghram clutch (sorry I dont that the part number)
But i cant recommend the hyd T/O bearing and here why.
1) There is no adjustability in the t/o beaing. initial set-up is a pain, you have to measure very accurately to get the correct spacing, so that you can order the right length piston.
and if you change clutch brands or type, you will may have to change the piston again. and you wont know it until the whole thing is installed and bleed!
which leads to:
2) any time you need to remove the trans, you must open the hyd system.
fluid loss, mess and you must re-bleed the system.
Before i owned one i thought it was great, then I had to change a clutch......
Jason
