  #25 (permalink)
Old 10-17-2008, 02:43 PM
LRcobradreamer LRcobradreamer is offline
Yes, it is three 2 barrel carbs with progressive linkage also called tri-power. Most of the time it only uses the center carb, until you push the go pedel and open the others at the same time. The change in sound is awesome. My brother had this same set up on his 66 GTO he bought new. I found this Cobra for sale last year and could not resist. PM me your e-mail and I will send some photos.
Google Pony Carbs for more info. They use Autolite Carbs and can size them from 600 cfm to 1000 cfm. Since I have a 302, then mine are 625 cfm total, which makes the car very drivable on the street. 345 hp at the crank per the dyno sheets when it was built, but I want to get it on a chassis dyno and get some rear wheel HP and torque numbers and a tune up.
Intake manifold also comes with it. Pony Carbs runs each tri-power set up on an engine to tune it before it is sold. So it should be a simple bolt on and go. However, I believe the past owner has adjusted it and per John at Pony Carbs it should get better than 17 mpg on a Cobra. He said a Mustang is getting 25 to 28 mpg with a similar set up.
Lee
