Thread: Dyno run
Old 10-17-2008, 08:22 PM
Plums Plums is offline
Alffie, that "shouldn't" happen if the tuner has disabled the requirement for the ECU to aquire a code from the BCM. BUT it is possible that it may need a re-link on the first start-up..... If the engine fires then stops (as opposed to just cranking) you will need to get it re-linked. You'll just have to wait and see...
