Old 10-19-2008, 09:45 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Good news!
To some, including cpteddie. If you have an earlier body style with the floor moulded in AND a newer frame with the floor pans welded in instead of the slats, you CAN cut out the entire fiberglass floor! this will give you a full inch on each side at the rockers, and up to two inches to the rear on each side! Just cut out the fiberglass floor pans and leave an inch or two all the way around then you will see just how far you can cut it out. It will also allow you to tilt the seat back a full 2"s!
About time for some good news for a change hey Eddie? This is especially good and neat for bigger guys instead of us wimps!
DV
