Old 10-19-2008, 09:51 AM
Joe Wicked's Avatar
Joe Wicked Joe Wicked is offline
I use multiple monitors at work, and I found that a program called UltraMon, gives you a bit more functionality than the standard Windows. You can actually set it up to where 1 monitor starts running the screen saver at the set time since you are not working on it while the monitor you are on remains active. There are different versions of UltraMon as well as other programs that have different abilities. Once you get used to using multiple monitors, it is hard to go back to just 1.
Why do they call it "Common Sense" when it is so rare?
