Old 10-21-2008, 02:49 PM
jeffy's Avatar
jeffy jeffy is offline
Cobra Make, Engine: ERA 289FIA 2131, 331 stroker by Dan Dalena with 48 IDAs by Jim Inglese, AC Cars AC8 "Rosso Chiaro" (PPG Nexa code FG39) by Connecticut Custom
Originally Posted by Jim Holden View Post
jeffy:
Just a reminder that my current (and your proposed) Weber setup does not have a provision for a thermostat. I have ended up putting one into the upper hose and blocking off the oil cooler in an effort to try and get some heat into the motor.
Jim
PS: Danny said, after rebuilding my set of Webers, that he would never do another set... so, I hope you are buying new.
FYI: My current motor is a Dart (4.25") iron block with Dart aluminum heads. The block has four bolt mains on all of the mains and required a custom (Stef) oil pan. I believe that AVIAD now makes a pan for this application.
Hi Jim-
Yes, we are going with new Webers; parts availability has improved a lot recently, I'm told. Rick Parker mentioned the thermostat issue to me as well, and has a plan for how to tackle it during the winter. We'll see how that works out. Thanks for passing along your solution; not sure what we'll do there.
We are using a 289 production block with the Dart aluminum heads and an AVIAD pan (used, if we can find a good one).
Hope things are all well!
Jeff
