Old 10-22-2008, 03:57 AM
fastraxsg's Avatar
fastraxsg fastraxsg is offline
Evryday is a roadstr day
Cobra Make, Engine: RHD Hurricane street roadster HM1081 aging nicely in the garage
I've stored vehicles over winters before on jack stands but always leave a bit of weight on the tires/wheels, I put a piece of plywood or similar under each wheel so they don't stick to the garage floor and leave marks. A breathable car cover with a soft interior that doesn't scratch would be nice too, keeps the dust and dirt out of the inside. Best if you put the cat out for the winter though. They tend to want to snuggle into and scratch up the nice seat material while hiding under the car cover. Don't forget some gas treatment for the tank if you aren't going to drive it, plus fill it all the way up so no moisture collects inside, drain the oil and fill with fresh oil too. Also good idea to remove the battery completely and put it on a solar battery tender. And, in the spring, drain the brakes and refill with fresh brake fluid. (probably over kill).
Over here, we put 'em on jack stands so the monsoon floods won't reach the bearings.
aka Fuzzy ............... "It is not the return ON my investment that I am concerned about; it is the return OF my investment".......from Will Rogers
